Originally posted by voodoochild
View Post
SRV PE WIRE.
Originally posted by Bill M View PostVolume 7, treble 7, mid, 7, bass 2. The use of 2 tube screamers, 1 set for clean boost, the other set gain 1/3rd, volume 2/3rds, tone to taste. There you have it, instant SRV tone.
Originally posted by voodoochild View PostI honestly feel like Stevie's tone was mostly the wall of amps he played through. Many don't know that he got his sound mainly from several amps at lower volumes which gave him a huge clean tone.
I got a great SRV tone once on a Harmony guitar plugged into a tiny Marshall combo!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by jmaf View PostYes, all that is perfect. And, the last detail, you need SRV playing the rig.
Originally posted by David Schwab View PostI've been saying this for years, but no one pays me no mind! For some recordings he had about TEN amps running simultaneously! Some of them were in the stairwells at the studio. This was in a GP story a while back.
Ive just wound my first set of pickups with the NOS 'SRV' wire.
I used a gray bottom and black top bobbin arrangement and .187 mags from Mojo: .688/.688/.710,.710,.630,.650 and wrapped around 8300 turns around the first bobbin. To my astonishment it read around 9K. The spools are marked as 42 AWG PE. So I ended up taking turns off by the handful until the bobbin read 7.9K, similarly the other two were high and even the lowest wound neck at 7500 turns needed some wire removal to bring the K down to 6.5.
I used Mojo PE on another set and that was in the expected turns range of around 8200 for 6.2K.
Now both sets sound great, harmonically rich though I slightly preferred the SRV set for a classic sounding overdrive its slightly less bassy and slightly more hollow sounding. This may be a result of not yet having waxed the SRV set or maybe its the wire. Next step would be to wind another set to the normal number of turns with the 'srv wire' ie 7900-8200 I expect this set would read around 9-8k and be great for blues rock style overdrive.
I preferred the sound of both PE sets to another set wound with BAE Elektrisola heavy formvar and .195 Mojo mags, which to my ears sounded a bit harsher and slightly muffled in comparison though did overdrive slightly more.
BTW I think Fender used 43 AWG PE for the first editions of Texas Specials, which coincidentally or otherwise is sort of matching this 'SRV' wire correct me if I'm wrong. Also do others think that perhaps this wire is actually 42.5 or 43 AWG? (I don't have a micrometer)Last edited by Lpone; 05-29-2011, 02:26 PM.
Originally posted by Lpone View PostAlso do others think that perhaps this wire is actually 42.5 or 43 AWG? (I don't have a micrometer)It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by jmaf View PostI've re-read this whole thread and I'm now convinced it's the wire.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Lpone View PostIve just wound my first set of pickups with the NOS 'SRV' wire.
& i have never seen a Texas special with 43 gauge wire"UP here in the Canada we shoot things we don't understand"
Originally posted by Lpone View PostAlso do others think that perhaps this wire is actually 42.5 or 43 AWG? (I don't have a micrometer)Pepe aka Lt. Kojak
Milano, Italy
