So I've wound a pickup for a custom lap steel console guitar I'm building and I tapped the coil multiple times. The first tap is at 5.67k, the second is at 7.88k and the end is at 10.11k.
I know I can use a rotary switch for the selector, but I was wondering if I can use SPDT on off on switch for it.
I know that energy follows the least path of resistance, and used a breadboard to test the switch. The wiring looks like this:
0--- 7.88k
0--- 10.11k ----------Output
0--- 5.67k
So with the switch in the middle, the output is obviously a 10.11k. But when you throw the switch up, the resistance gets cut since it leaves the coil at an earlier path of lower resistance. Then the same happens when you throw it down, the lower resistance is what is sent out.
Now only measuring resistance, this seems to work out. However, I know that pickups have more involved such as inductance which I have no tools to measure. So my question is do you think this setup would work, or would there be signal bleed from the higher outputs?
0--- 7.88k
0--- 5.67k
