blade humbucker dimensions
  • #16
    Originally posted by Zhangliqun View Post
    Anybody know where to get some 1010 steel round stock from 3/16" to 1/4"? Been all over the net and it thoroughly eludes me.
    You can get 1018 from McMaster.
    http://coneyislandguitars.com
    • #17
      If were on the topic of blades
      some new stuff Mojo got coming ,bucker blades & some other stuff
      New Products
      "UP here in the Canada we shoot things we don't understand"
      • #18
        Those Strat blade bobbins take 1/16" (.0625" - 1.5875mm) blades.
        David, can you meaure the height of the blade please? I'm trying to find out how tall the pickup would be with the blade inserted.
        Last edited by David Schwab; 06-24-2011, 03:26 PM. Reason: fixed closing quote tag
        • #19
          Mojo has HB slugs in 3/16" 1010
          Mojo Pickup Parts » Mojotone Humbucker Slugs Nickel / 6
          look down at the bottom L corner, it says 1010
          making 63 and 66 T-bird pickups at ThunderBucker Ranch
          • #20
            I'm using 3/4" high blades. Mine are flat on the top since I'm putting them in a closed cover.
            The Mojo blades are have a 10.25 radius. The list the dimensions as: 2.265 Length x .625 H, .880 H, .825 H. I'm not sure why there are three heights listed.
            The way these are normally used would be to have a baseplate with a rectangular cutout in it. The blades and magnet poke under the baseplate.
            Here's one for the Tele bobbins from GuitarPartsUSA:
