I thought I'd throw this out there and see what washes up on shore. As a matter of course I tape my magnets to insulate them. I've tried lacquer dips of various types and brands and no matter how loose I wind the coils short to the end poles. Nail polish the same thing. I have my old Fralin pickups laying here, the ones that got me into pickup making because they would never give it up through any guitar or amp I tried them through. So I cut the coils off, so out of curiosity I put my ohmeter probes across the magnets and no reading. I pushed real hard tried to dig into them and no reading. The magnets don't look coated at all, so I took an exact knife and scraped into and sure enough they ARE coated with something that I could chip off. Whatever it is, its as hard as a super glue coating, and is matte finish, not gloss. I am real tired of using tape and looking for ideas what they might be using. I've research electrical varnishes and lacquers and sure they are made but you have to send out and RFQ and no one will talk to you unless you want to buy 50 gallons of the stuff, and I'm not even sure it would work either. I found some stuff made by Dolph but again, they don't answer email and you can't find anyone who will sell you one can of the stuff to try out. So looking for ideas. Its has to be a hard almost invisible finish , hard as super glue, be easily wiped off and not thick so you don't have crap all over the magnet tops and flatwork. Super glue would work but how would you apply it without gluing your tongue to your knee in the process. Joe Gwinn suggested marine epoxy paint but you'd have to mix up enough to dunk the pickup in so there would be alot of wasted product and probably too thick to use. Ideas?
Magnet insulation
Tags: None
I'm glad someone has mentioned this because I was about to ask..., just wound some strat pickups several times ( PITFA that was ), same thing no matter how loose it was wound it shorted to the outside poles? was thinking of some kind of poly laquer? but not sure if it would work ? there must be something ,
And can I mention Q for a moment , mine seems to be around the 2.4 even on low wind numbers? this is with strat pickups , I was thinking that maybe the tape was something to do with it ?
Mick
How about vinyl sanding sealer? Takes about an hour to dry and I am sure you can make it thin enough if it isn't already. Apparently it leaves a nice finish on the pickup as well. I read on SK's site that he uses it for potting and it will probably work for what you want.
"How about vinyl sanding sealer? Takes about an hour to dry and I am sure you can make it thin enough if it isn't already. Apparently it leaves a nice finish on the pickup as well. I read on SK's site that he uses it for potting and it will probably work for what you want."
I Thought about the stuff they use on floorboards after they sand , that stuff is pretty hard but it could be too glossy? I'm not sure if it's the stuff you mention .
Mick
Originally posted by mick View PostJust had a thought on this , the mags have a very slight oily residue on them , if it's not wiped off properly the laquer won't stick properly , maybe I need to dip my mags in some kind of cleaning solvent ?
Mick
Use good old fashioned nail varnish. It's cheap, 1 bottle minimum order and dries in minutes. i opt for clear nail varnish though I have been known to use red and black. ( On the pickups that is. Just want to make that clear, so there's no confusion. Oh bollocks what have I saiD ...?...)
sigpic Dyed in the wool
Deft??
So you're not getting pole shorts with this stuff and its virtually invisible when dry? Since you've been to Fralin's shop did you happen to notice what they're using? The stuff they're using dissolves in lacquer thinner so it can't be anything too exotic.http://www.SDpickups.com
Stephens Design Pickups
Deft??
Where do you buy this stuff, Lowe's , Ace?
Nail polish never worked for me, its too soft, especially the sparkle pink with little stars in it :-) Seriously though I could never get it to work and tried various brands.....http://www.SDpickups.com
Originally posted by mick View PostDo you tell your mrs it's you who takes it and not the kids ?sigpic Dyed in the wool
Originally posted by Possum View PostSo looking for ideas. It has to be a hard almost invisible finish, hard as super glue, be easily wiped off and not thick so you don't have crap all over the magnet tops and flatwork. Super glue would work but how would you apply it without gluing your tongue to your knee in the process. Joe Gwinn suggested marine epoxy paint but you'd have to mix up enough to dunk the pickup in so there would be alot of wasted product and probably too thick to use. Ideas?
Another alternative is thinned urethane spar (marine) varnish, first air dryed, then baked in a toaster oven, to ensure that the film is fully hardened before attempting to wind. Don't forget to wash things in acetone first, to remove all grease before attempting to coat the magnets.
Why marine varnish? Because marine varnishes are the best one can buy at retail, and although they are expensive compared to non-marine products, it makes no difference in the quantities used on pickups.
Why does the film have to be so hard? Because the pressure is very large. Let's run a numerical example:
Take a 8,000-turn coil wound with #43 wire. The winding tension is something like 26 grams. The end magnets are therefore being pulled towards each other with a force of (0.026)(2*8000)= 416 kilograms, or 915 pounds. The effective area of each magnet bearing the load is about 3/16" by 7/16", or 0.0820 square inches, so the pressure is about 915/0.082= 11,157 pounds per square inch, on average. This well exceeds the strength of many plastics, both initially and especially over time as the pressure causes the inner wires to creep through the film
The pressure will be reduced as the bobbin crushes slightly and as the wires in the winding slide about a bit, and/or due to a loose wind, but still it's easy to get large numbers, so the coating must be quite hard right from the start to survive.
I got my deft from Lowes, a quart was like 4 bucks, its clear lacquer sanding sealer. I just dip the whole bobbin in for a few seconds and hang them to dry. As I said you will have to watch for that last little drip that will dry on the end if you dont wipe it off. If you dont want any shine on the flatwork at all just wipe the flatwork off after a few minutes and leave it on the mags.
To my knowledge I have had no problems with the coils shorting yet.
Something that springs to mind:
I seem to remember Possum telling me that the magnets are sometimes a bit loose in the flatwork and the effects of lacquering help to stick it all together. OK, that may be where the problem is. I say this because if the flatwork moves on the magnets, it will get trapped between the flatwork and the magnets on the end poles. in the process the coating on the wire is stripped and so is the lacquer on the magnets.
This oversize/undersize issue with bobbins and flat work is a right royal pain in the ass. In order to get around this problem, I always resort to using a set of reducing punches.
These are readilly available at Micro mark.
http://www.ares-server.com/Ares/Ares...oduct&ID=82390
Obviously don't use these on the side of the flatwork that shows.
Lacquer after.
My personal choice is Fiddes Bonehard Lacquer. I guess by the name of it, it's nitrocellulose with viagra in it !sigpic Dyed in the wool
