Originally posted by frankfalbo
View Post
An example of this is the Lace pickups that David King mentioned. Assuming that the Wiki article is correct, these pickups intend to magnetize the string with a lower than normal field strength to avoid string pull, but still get a high output. So you use weak magnets and a core structure that results in this lower field level at the string. In order to make up for this lower than typical string magnetization, you attempt to capture more of the flux from the vibrating string and get it to pass through the coil. In order to do this, you might use some steel (high permeability), or possibility other material such as ceramic, to guide the flux from the bottom of the coil back up towards the string in order to shorten the path through air. This steel would also tend to increase the permanent field strength at the string, so you have to be sure to use weak enough magnets.
*And despite your sarcasm, it has nothing to do with my beliefs. It is how the physics works. I suggest again looking at the solution referred to in the "Light reading" discussion. You do not have to understand the math to follow the basic steps.
