New Polymer Neodium magnet VIDEO, standard pickup constructions tests and comparison
  • #76
    We recorded another track.
    Pickup with Neo-polymer magnet, similar to the PAF
    Blues Backer Br 2 channel.mp3
    Merry Christmas
    YouTube channel
    Contact us:
    sthandling@gmail.com
    • #77
      We(Me & a guitar player from a metal band just did some magnet swaps in a high gain humbucker of mine (sorry no sound clips)
      we compared
      A5,A8,Mr.Candy's 75mt NIB
      The A8 & the NIB are very nice sounding & similar ,both are bright & warm ,not harsh like the A5
      & sound a little sweeter but a little more compressed like a ceramic magnet ..still a great sounding magnet ...just another option for great tone
      well done Mr Candy
      "UP here in the Canada we shoot things we don't understand"
      • #78
        we compared
        well done Mr Candy
        Yes, these magnets significantly affect the tone, the sound has less spurious components in the high,
        low is harder and more localized. High constituting more like a bell. What do you call this compression is nothing but underline the lower middle, it growls .
        Try to wind one coil 120 TPL, another (closer to the bridge) 60-70TPL + 150-200 turns. The magnet will highlight different parts of the AFC.
        YouTube channel
        Contact us:
        • #79
          Tell us again how to get 120 tpl on a hummer coil when the estimator says 89 tpl is 100%.
          Coil Estimator
          Is this some more of that Smoke and Mirrors, That seems to be Prevalent on here these Days!
          T
          Terry
          • #80
            If one does this, how does one tell magnet effects from coil effects?
            • #81
              +1
              Terry
              • #82
                It does have some of the characteristics of a ceramic 8 magnet
                & some of the warmth of alnico
                • #83
                  Well its about the same strength of a ceramic 8 magnet, so that stands to reason. My experience with neo magnets is they have a warmer tone than ceramics though. If you are using a strong neo, you have to watch how much you wind on the pickup or it will get very bassy real fast.
                  As soon as my magnet wire comes in the mail (ran out over the weekend) I'm going to wind up a dual blade STrat pickup with one of the magnets, and I'm going to try one of the humbucker magnets in one of my HBs.
                  http://coneyislandguitars.com
                  • #84
                    Coil Estimator
                    T
                    I do not need this calculator, we have an emulator winding machines for debugging process.
                    He reports
                    42 AWG - 90 NT
                    43 AWG - 105 NT
                    44 AWG - 114 NT
                    in a layer.
                    copperheadroads with a guy from metal band tested high output pickup.
                    I assumed that there was a 44AWG.
                    And what the Bible says that you can not blow off a little overlap?
                    YouTube channel
                    Contact us:
                    • #85
                      Where did you see?
                      I offered to make a difference in the phase characteristics of the coils.
                      YouTube channel
                      Contact us:
                      • #86
                        We made ​​a new device for sensor calibration.
                        We managed to get the solenoid current of about 11A, which has resulted in the values ​​of the magnetic induction of about 189G.
                        We got sensor A1302KUA-T. In order to do that analysis of his work.
                        We got conflicting data from the instance, compared with the existing sensors and we have our device.
                        Just want to make an explanation for our device.
                        We again contacted the manufacturer of our device that would ensure proper calibration of our device
                        He reiterated the correctness of the calibration, but when we checked the sensor SS496A on a new installation (with the higher B),
                        then we have discrepancies between SS496A and our device.
                        It turned out that our sensor device DHK-0.5A (Latin transcription) was cover (shrinkable tubing).
                        When the calibration solenoid cover does not make mistakes. We have removed the tube from the place of measurement.
                        And we began to receive analogous data in comparison with SS496A (after the calibration of the new solenoid).
                        Obtain higher values ​​of current in the solenoid is problematic.
                        We need a thicker wire and more current, but with increasing wire gauge solenoid density decreases (in the formula "n"), to compensate for this increase must be current.
                        Therefore, for higher values ​​of applied pulse modes and superconductors.
                        The results of measurements, we think that the sensor 1302 is not linear, at least in our existing instance.
                        On this same reported here RedHouse. But the trick lies in the fact that this instance can not be in the presence of the calibration reference value.
                        Most likely, these sensors are generally not suitable for measurements of static magnetic field.
                        Perhaps the sensor is designed to measure angular velocities.
                        For testing, we obtained data at two points, with a current in the solenoid 11A and 4.5A.
                        We measured the two magnets, with a low charge (an experimental) high.
                        We also measured the SD of the ceramic magnet pickup SCR-1N. Unfortunately for the sensor SS496A magnetic induction of the magnet above its upper range.
                        Vo- SS496A
                        Vo- A1302KUA-T
                        SS496A Low mag
Name:	469 Low Mag.JPG
                        ∆V=0.908v
                        Bmag(Isol-4.5A)=341G
                        Bmag(Isol-11A)=361G
                        Bmag (data sheet)=363G
                        SS496A Hi mag
Name:	469 Hi Mag.JPG
                        ∆V=1.805v
                        Bmag(Isol-4.5A)=679G
                        Bmag(Isol-11A)=718G
                        Bmag (data sheet)=722G
                        A1302KUA-T Low mag
Name:	1302 Low Mag.JPG
                        ∆V=0.643v
                        Bmag(Isol-4.5A)=440G
                        Bmag(Isol-11A)=464G
                        Bmag (data sheet)=494G
                        A1302KUA-T Hi mag
Name:	1302 Hi Mag.JPG
                        ∆V=1.304v
                        Bmag(Isol-4.5A)=892G
                        Bmag(Isol-11A)=941G
                        Bmag (data sheet)=1003G
                        Our device low mag
                        Bmag=368G
                        Our device Hi mag
                        Bmag=758G
                        to be continued.....
                        YouTube channel
                        Contact us:
                        • #87
                          A1302KUA-T SD cer. mag
                          ∆V=1.753v
                          Bmag(Isol-4.5A)=1200G
                          Bmag(Isol-11A)=1265G
                          Bmag (data sheet)=1348G
                          Our device SD cer. mag
Name:	SD Cer Mag.JPG
                          Bsd=945G
                          Exel files calibration calculations
                          Calculations B.zip
                          YouTube channel
                          Contact us:
                          • #88
                            aaaaa
                            Does it hurt...?
                            Pepe aka Lt. Kojak
                            Milano, Italy
                            • #89
                              Well those new readings sound more accurate.
                              • #90
                                He reports
                                42 AWG - 90 NT
                                43 AWG - 105 NT
                                44 AWG - 114 NT
                                in a layer.
                                We were just testing magnets in a 17k bucker with double row Allen screws,that i usually use a A5 or A8 magnet in ( with pretty much same winding pattern as a JB)
                                There is no designing going on with your magnet yet, just a brief swap with beer,whisky & a cranked orange amp......no r&d until I get back in the spring
                                Overlap ?................Shhhhhhhhhhhhhhhh!!!!!!!!!!!
