Extech tutorial
  • #46
    Looks abnormally opaque. I would suspect a protective layer if I saw that. Has anyone tried working to peel it from the edge/corner (the marks in the right upper corner make it look peelable)? Some modern plastic stickers can adhere really well and are quite thin (encountered some on a plastic Xylitol gum container top that I had to look at under magnification to find the edge to peel the labeling sticker off the top--I couldn't do it with a fingernail).
    • #47
      Originally posted by Mike Sulzer View Post
      Here is a snapshot of the Extech display with blurring coating, compared to another similar cheap display.
      [ATTACH=CONFIG]19270[/ATTACH]
      That would make me go blind.
      www.sonnywalton.com
      How many guitars do you need? Just one more.
      • #48
        That looks like the shipping protection film is still there. Try picking up a corner and peeling.
        • #49
          Yep, I think I can see the edge of it in the pic. Try warming with a hair dryer or something. No way did they intend it to be like that.
          • #50
            Extech 380193 serial protocol
            Anyone using the the Extech for datalogging over the serial link needs the command/protocol document (~77k) which is sometimes available by request.
            Note the 1200 baud, 7 bits, 1 stop, EVEN parity.
            Someone should probably write a Python app data logger for this one.
            Extech 380193 Protocol.pdf
            "Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
            • #51
              Thanks Joe. With great care I managed to get a knife under it and get up enough so that it would not rip when pulled. I could not do it without a tool.
              • #52
                Wow, I can see the screen again. Kind of embarrassing, but I'm glad I asked.
                Thanks all.
                Rob.
                • #53
                  Thanks all.
                  Rob.
                  Wow!!! It worked out great ,Don't be embarrassed . A stupidest question is one you don't ask
                  "UP here in the Canada we shoot things we don't understand"
                  • #54
                    ....With great care I managed to get a knife under it and get up enough so that it would not rip when pulled. I could not do it without a tool.
                    WTF?
                    Aw Mike, ya serious?
                    With all the brow-beating posts over these years, and here you are f'n shitting me/us (I hope) that this is just a case of un-removed packing material over your display, that you are just now peeling off?
                    Brings a whole new level of "understanding" to your posts! but then, in the interest of luv-n-understanding, ...I digress...
                    Well, shite, at least a redeeming thing, ....many will know what to look for...
                    -Brad
                    ClassicAmplification.com
