Been listening to some Big T Analogman ( Fralin ) pickup clips. I understand hat they went for longer magnets and possibly 42g wire. Can anyone share some insights into this pickups design or specs.
Big T makeup
6,4 K DC
2,41 H
8,6 K peak res.
1100-1200 Gauss
aussumed wire awg 42
The Fender Telecaster twisted neck PU uses even longer magnets than the Big T. At whopping 0,79" tall they are the longest magnets I've seen on a Tele neck PU. And unlike the Big T which keeps the bobbin chassis stock, the twisted Tele neck Pu is a high boy that wires the magnets all the way up and down.
Originally posted by Mark Hammer View PostShould one assume that by using longer magnets, it is possible to: a) have more turns in closer proximity to the magnets, and b) have a lower DCR for the number of turns, since the circumference is shorter for many of those turns?
On a Tele Bridge Pickup, most are already too bright for me.
I usually make them shorter, not Taller.
Would depend on what sound your looking for.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Longer magnets will make them stronger.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by big_teee View PostMaking it taller, Usually gives a brighter pickup.
T
Just make it closer to a Strat pickup. I've never liked most stock Tele neck pickups. And honestly, who cares if it's a slightly larger size and doesn't have the cover on it.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostJust make it closer to a Strat pickup. I've never liked most stock Tele neck pickups. And honestly, who cares if it's a slightly larger size and doesn't have the cover on it.
Originally posted by Telemachos View PostOouutch!! That's almost blasphemy. There are millions of die hard Tele players that really care. They take a large part in the vintage world. Off course there are others that don't care about it. There is a sound in Tele neck PU that is very special. Building a PU closer to a Strat can bring it too close to a strat sound which not evryone likes to have on his Tele. Yeah, all a matter of taste.
http://www.buyanalogman.com/ProductD...=AM-BIGTPickup
Read the description (emphasis added):
The normal neck pickup in a Telecaster is just not that great... Leo originally thought it would be used to play bass lines, so all Teles up till the late 60s had an odd switch set up the forward position ran just the neck pickup with a preset BASSY sound. Almost everyone rewires the switch so you can use the neck pickup normally, with normal tone control. But the neck pickup does not match the wonderful bridge pickup for output or clarity. Many players (KEEF!) carved up their old Teles and mounted a humbucking pickup in the neck position, but that's no longer needed with the BIG-T
Here's a Tele someone commissioned me to put together with a Lace Chrome Dome at the neck:
Clearly not a Vintage setup, with the DiMarzio Fast Track at the bridge, but it was a nice sounding guitar. The neck pickup sounded a lot like a Big T, but it is Strat sized.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostBut the Big T pickup sounds like a Strat neck pickup. This thread is asking about the Big T pickup. What do you think its talking about?
What the makers mainly tried to come up with is a neck PU that would match the volume level of the bridge PU better w/o loosing definition and clarity. The beauty of this PU is that they really achieved their goal w/o having this neck PU loosing its' typical Telecaster tone too much. While other PUs like Fender's twisted Tele neck PU definitely sound a lot more like a stratocaster PU, this one sounds more teleish. But again, we all might hear it different, so all IMO.
Originally posted by David Schwab View PostSo clearly many Tele players dislike the neck pickup.
Originally posted by David Schwab View PostThe problem with the "vintage world" is they have their head stuck in the sand somewhere. Personally I don't see the fascination in wanting your guitar to have some exact tone as some other guitar. Find your own tone.Last edited by Telemachos; 04-22-2013, 08:50 PM.
