P90s....
  • #31
    Originally posted by big_teee View Post
    I don't know much about P90s, but what do you need the lug for?
    Is that to keep from soldering to the baseplate?
    I'm basicly a Bucker and SC guy!
    T
    Yes, in place of soldering directly to the baseplate, like this:
    http://www.jeangodbout.com/lennon-le...ck-dog-ear.jpg
    I prefer this as it was the way it was originally done & I'm a bit of a traditionalist (gasp) - but also for the functionality.
    For P90s I keep the braided lead wire in place in test guitars. Using those solder lugs allows me to swap pickups in and out by only unsoldering/soldering the hookup wire to the lead and lug/tag - makes it a very fast procedure & there's no alligator clips, wire nuts or anything else.
    It also makes it very easy to swap soapbar and dogear base plates to test in different guitars - because nothing's soldered to them.
    Bobby, www.TysonTone.com
    • #32
      I think if one were to put two A9s in a P-90 it would effectively lower the action of the guitar or pull the pickup up into the strings. Them's allot'a Oersteds!
      • #33
        Originally posted by rhgwynn View Post
        No need to be contentious man. That has no place here.
        I've done some with PE and they came out fine; but "experimenting" can get expensive.
        I just wanted to see what others have done.
        I don't think that was contentious. That's how you learn and discover things. We all have to do it. We can't tell you what you like and what to do.
        Just wind one pickup with each. if you want to do a stock standard P-90, just pick poly or PE and wind it to spec.
        However, you might want to try something new, different wire gauges and amounts of turns, etc. In that case you have to experiment, wind coils, strip the wire off, wind more coils, and so on.
        http://coneyislandguitars.com
        • #34
          ....maybe I just suck at searching forums...
          -Rob
          The more you use it, the better you get so try using it more, everyone here will benefit that way.
          -Brad
          ClassicAmplification.com
          • #35
            Isn't that the same thing Rick Turner was saying that you objected to?
            • #36
              Look David, I know he's your bud so I don't expect you to see the point, but No, not at all.
              Here in this thraed there was a general no-effort thing going on as you well know, in the other thread I was asking Rick a specific, singular, and direct question, as he "seemed" to be posting as if he knew something on the subject. I should have known better, par-for-the-course, and all that, but live-n-learn I suppose.
              David, when you are asked a direct, and specific question, you generally respond politely unless of course there is some extreme lameness going on in the thread (as is in this thread). The computer lessons (crap?) was a bit unsulting as I've dealt with more bytes than Rick will ever pass in the entire rest of his life, as I'm sure you recall.
              (or, maybe not)
              Anyway I'd just-as-soon not get into a "thing" with ya about that other thread, if it's all the same to you.
              I appreciate the man (Rick Turner) but I'll need to appreciate him w/o directly addressing him, probably best for all that way.
              -Brad
              • #37
                Originally posted by Spence View Post
                Gibson have got a habit of doing this so the little people lke us can't supply P90s with the right covers.
                I am currently working on my own covers for that reason.
                I meant to add these a while ago.
                They are my own vacuum formed covers which fit the Gibson routs and those silly modern baseplates fit inside.
                sigpic Dyed in the wool
                • #38
                  Very nice Spence.
                  • #39
                    Thank you.
                    I had some help from Jonson as always.
                    • #40
                      Nice one Spence
                      I'll bet you make your own curries too.
                      Cheers
                      Andrew
                      • #41
                        Originally posted by the great waldo View Post
                        Nice one Spence
                        Cheers
                        Andrew
                        How did you guess? :-)
                        • #42
                          Nice one Spence
                          Cheers
                          Andrew
                          I bet he can make a mean Eggaroll
                          "UP here in the Canada we shoot things we don't understand"
                          • #43
                            Great Book Spence
                            My sister gave me a copy before I moved to Austria (Minimal curry house region) My copy looks a bit more like the dish on the right. Just for your interest, the secret of the perfect onion bhaji is to put some fennel seeds in with the mix.
                            Long live the ceylon meat extra hot!!
                            Cheers
                            Andrew
                            • #44
                              Ohhhhh… nice! I like to make my own, too.
                              Vacuum formed curries are what's up. Oh. …Wait. Huh?
                              Seriously, both look delicious! I'd enjoy a deep dish full of either.
                              • #45
                                Originally posted by John_H View Post
                                It's not for everyone, that's for sure. I had much better results after I built the chainsaw powered winder. I don't guide the barbwire by hand. Instead I oscillate the hand held winder back and forth.
                                Just now saw this thread.
                                You need the woodchipper - it is great for finishing guitar bodies and wooden pickup covers but is even better for dealing with angry customers or non-responsive suppliers.
