Help with this pickup - odd bobbin
Just thinking out loud here.
What if you didn't use the pink bobbin holder?
Take the blade in the middle and make a bobbin out of thin fiber or epoxied thin cardboard.
Tape over the blade and with little tension wind over the taped upblade making a one piece bobbin.
Maybe do some paper, or cloth taping over and around it when done.
Put it back in the pickup.
You will need to leave enough blade sticking through to contact the magnets.
GL,
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Work out the inside length you need with a piece of string then wind it as an aircoil around a pair of strat strap buttons set to that length. Wax dip the coil then tease it into shape and allow to set before taping it up. The shape don't matter while you wind so as long as length is right even 3 buttons would do it then a few bits of cotton to tie it or small bits of tape to keep it together while potting.
Ok, interesting. So set up a jig with two strap buttons or the like with the correct inside length, then release the retainers and then cotton ties, tape wrap, wax dip…. tata.
I see that mojotone has a blade bobbin that might do the trick as feel, in which case i could loose the open ended bobbin. I have some options now. Wondering if anyone has seen this type pickup before.Last edited by angelodp; 04-26-2014, 05:30 PM.
Cotton ties before you release it or you will just have a pile of wire, then pot and tease into shape before you tape.You can still do another quick dip if you want the tape waxed. Plain cloth tape about 1/4 in wide is the norm rather than masking tape.
Hi Those things are a nightmare to do. I've done a couple which had wax holding the whole thing together. They end up not being economical because of the time involved, I just did them as a favour for some regular customers.
Cheers
Andrew
Originally posted by angelodp View Post
Can someone explain how it works?
It is a Single Coil?
Does the screws do anything, or just the blade in the middle?
Terry
Its like a P90 except that the magnets transfer to the blade and the screws as well. Once the bobbin is in there is a black thin shield of plastic like material that covers the blade and the coil. I have not heard the pickup yet so I cannot comment on tone.
Great Waldo, how did you tackle the bobbin issue. As of now I have made a temp bobbin out of plexi with two screws spaced correctly. I have some shrink wrap on the screws and may add some wax paper on the surfaces as well. Then I can do the wind and wax pot, remove the screws, separate the coil, wrap with paper, install. I am already close to three hours work on this pup!!!
Hi Angelodp
I ended up making a bobbin core with kabuki tape (tamiya model masking tape, the yellow stuff) around the core and waxed the coil. I then took the coil off the bobbin and taped the inside of the pickup, dumped the original coil holder beforehand. then the coil was laid in the tape and taped over and waxed poured over to hold the coil down. Closed the whole pup and gave it a wax bath (quick soak just to let the wax run in and help solidify the insides) It did actually work. it probably wasn't the right way of doing it but it worked. Next time I would refuse the job or charge some ridiculous price to cover the time and hassle.
Cheers
Andrew
