Any of this group still around?
American Wire Corp. Sandy Hook, Conn. Brown Plain Enamel wire ?
Sure, and I've burned through about 2 oz on my 5.5lb spool so far...Last edited by David King; 10-09-2016, 05:50 AM.
I virtually gave away almost 30 pounds of it a few months back. I'd had it for a few years. Bought it, hoping that AWC would have gotten the PE issues sorted out since the last time I used it.. around 2004. Nope. Wound a few coils, shelved it, and never touched it again.
The copper is not annealed properly. That's why it skips, bounces, and breaks when you wind it. The insulation is not cured properly. That's why it smells.
If anyone has some to sell, I may be interested, but it has to meet diameter specs on a micrometer. I would need a couple inches to measure since most people use micrometers wrong, even the wire sellers get it wrong.http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostIf anyone has some to sell, I may be interested, but it has to meet diameter specs on a micrometer. I would need a couple inches to measure since most people use micrometers wrong, even the wire sellers get it wrong.
Just out of interest what is the correct way of using a micrometer to measure pickup wire ? Thank you in advance.
Cheers
Andrew
Originally posted by 12xu View PostWhy do you guys prefer this wire to the electrisola?
Just curious
Cheers
Andrew
Originally posted by WolfeMacleod View PostOnly he knows the correct method, cause only his method is right, and of course, he won't share with anyone.
