Anyone know if stewmac bobbins will fit gibson spacing covers?
stewmac bobbins and gibson spacing?
Tags: None
I bought 2 HB kits from stewmac... then I realized a simple thing: the have the same polepiece spacing.
Isn't it a bad thing?
Should I simply don't care of the differencies from neck and bridge position?Biarnel Liuteria
Italian handmade guitars and basses
http://www.biarnel.com/liuteria/
http://www.myspace.com/biarnel
spacing...
No its not a bad thing, early gibsons all had the same spacings, I only sell one spacing, where it really helps to have different spacing is on big archtop guitars, you see it alot there....http://www.SDpickups.com
Stephens Design Pickups
Yeah, I can also verify that 50 mm covers fit the SM HB kits.
It’s a shame SM don't have covers that match the kits they sell, as they are an excellent source for starting out. I mailed them about it and the repose was "we cannot find covers that match"!!! I think that the real answer should have been “We cannot find cheap enough covers so that we can earn enough money on them”.
SM spacing
Actually SM bobbins aren't 50mm I figured it out once when they sent me pole spacing specs on their bobbins, they are like 50.3 or something thats slightly over. You'll notice this if you use authentic spec pole screws the heads will bind some on the end holes, the metric screws you guys use fit fine though...http://www.SDpickups.com
Originally posted by Possum View PostActually SM bobbins aren't 50mm I figured it out once when they sent me pole spacing specs on their bobbins, they are like 50.3 or something thats slightly over. You'll notice this if you use authentic spec pole screws the heads will bind some on the end holes, the metric screws you guys use fit fine though...
Originally posted by Possum View PostNo its not a bad thing, early gibsons all had the same spacings, I only sell one spacing, where it really helps to have different spacing is on big archtop guitars, you see it alot there....
Do Gibsons come with different spacings now? I haven't looked closely at any in years.
I mean it sounds like a good idea, but the difference so small... even Fenders have the same spacing.
I'd do like you do and sell the same spacing. I got so tired of string spacing issues on various basses that I'm just using a blade now.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by PoorMan View PostHey, Schwab. You got the web handle "Old Timer". LOL! I'm ith you bro!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
ahem.....
fuck every god damn one of you..... ha :-)
I'm 57 and I imagine there must be someone here older than me, heck Lollar is 75 right? :-)
Actually some early PAFs DID have neck spaced pickups, that provide-net jerk bozo has a picture of one, they must be pretty rare though.....http://www.SDpickups.com
Originally posted by Possum View PostI'm 57 and I imagine there must be someone here older than me, heck Lollar is 75 right? :-)It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
