Originally posted by David King
View Post
Unless that was only for toasters, in which case blades might be something else.
http://music-electronics-forum.com/t13530/
FWIW, according to an assembly diagram provided by Chip Todd, official specs for T-60 (guitar) blades are:
.859" x 2.491" x .062"
Material: Low Carbon, Mild Steel
Deburr Completely
Plate: Copper Flash, Nickel Plate, Chrome Plate
.062" = 1/16" = a bit thicker than 16 GA (maybe .062" is with the plating?)
I imagine the T-40 used the same thickness blades.
(My T-60 blades, which don't match any documented version, are .615" x 2.273 x .075" = 14 GA, bare steel)
If I were the OP, I think I would take T's advice and either build or buy a pair of "normal sized" (whatever that may mean) dual blade pickups.
