I would say your latest assembly is close to the original T40 design (PV started with ferrite blades and switched over to steel blades with a central magnet). So the original spec of 3750 turns would be a good starting point. The only issue would be if your magnets are shorter than the originals and you couldn't fit 3750 turns between the flats.
You would be looking to match the inductance- but we don't know that. A short, fat coil will have higher inductance than a tall, skinny coil with the same number of turns. But without having the dimensions of the PV ferrite-blade T40s, its all moot; the only alternative is to tune by ear and taste.
I am looking to match the resistance, correct/
