Is it possible to accurately describe the tone of magnets and/or pickups?
  • Is it possible to accurately describe the tone of magnets and/or pickups?
    I have been trying to come up with a system for describing the tonal properties of magnets of the same alloy that come from different suppliers. It is obvious that a variable describing overall EQ (bright vs. dark, or bass,middle,treble balance) is needed and a second variable that quantifies the density of harmonics (fat vs thin?) would be useful. It also seems important to have a variable that describes how smooth or harsh the tone is at high frequencies and possibly a fourth that deals with how open (vs. compressed) the tone is.
    It would also be useful to have a similar system for pickup tone. A few established pickup makers have attempted to describe their products with variables like EQ, output level and 'attack' but these descriptions seem to leave out a lot of important tonal information.
    Is it possible to accurately describe the tone of magnets and/or pickups with a few (<6) key variables?
    What's left out? I'm sure there's the consideration of what real life guitar players can cognate I suppose they could include "relative to a typical PAF" or something to add scale to the image?
    FWIW I've never thought that the typical bass, mid, treble references were adequate for describing pickups. I really think you'd need AT LEAST six bands of eq AND a relative scale to known pickups if "I" were going to get my head around what it might sound like. But again, try that with Jhonny Rocker in his living room studio playing into a POD, Sansamp or Line 6. The typical demographic for these products gets confused when you say things like "upper midrange", "higher treble frequencies" or any expression that uses the abbreviation Hz. As a result I don't think there's going to be much outside of what people (likely people here on this forum) that own spectrum analyzers and such have tested for themselves. It'll be a small list. If "I" owned a spectrum analyzer and tested every pickup I've used in my life it would be a small list. But I'm an amp guy and not a pickup guy. But my point is that it's a tall order. Though like you I wish it weren't.
      Well, some of the "missing tonal information"...is going to have to do with the guitar the pickups are installed in, among others the scale length, pot values, the type of bridge, string length behind the saddles, the pickup's location relative the the strings both vertically and horizontally, and that's before you get into the shadier areas of 'tonewood' or the even shadier artistic intentions of the musician with said pickup. Fo'shuh some of those variables you can describe objectively, but there are far too many combinations for the pickup maker to take into account when describing their product. As Chuck says, is is down to the 'real life guitar player' to fill up those holes in the text and make an educated guess at what he's going to get in the end. And we haven't even talked about amps yet.
      A pickup maker who states his pickup is the sole factor in the player's tone and says 'it'll give you this at 2.5k Hz' is either misguided or a crook of some kind. The best he/she can do is to quantify how much he/she can't predict, and live with it. The players have to live with it too. And most of the time they do
        Thanks for the inputs - they indicate that I need to provide some background and restate my question in clearer terms.
        While every element of a player's setup affects the tone that he gets from his amp, it is possible to isolate the contribution from the pickup magnets by holding all of the variables, with the exception of the magnets, constant. Those who have made accurate tone samples of different pickup models know how to control everything that is downstream from the pickup and experienced winders can control the variables in their winding setup well enough to make a few test samples that have coils with similar tonal properties.
        Assuming that all the variables affecting tone except the Alnico 5 pole pieces in a set of Formvar-wound, strat-style single coil pickups are held essentially constant, the tonal properties of different magnets can be compared by winding a series of pickups, sequentially mounting them in the same guitar, adjusting string height, etc. to predetermined values and plugging them into a test amp that has been warmed up long enough for its tone to stabilize before each test. Performing this test with Alnico 5 pole pieces from the 6+ magnet vendors that have been discussed in other threads on this site, will yield 6+ tones that are, in some cases, significantly different from each other.
        I believe that it would be useful to have a clear way to describe these differences - both in discussions on this forum and in explaining to luthiers and musicians the tradeoffs associated with putting different magnets in their pickups. I further believe that the descriptions need use variables that describe tonal qualities as perceived by a human observer rather than numerical parameters that can be measured with an LCR meter, scope or spectrum analyzer.
        So - to restate my original question in clearer terms:
        Is it possible to describe the tonal qualities of different magnets using a few (<6) perceptual variables?? If so, what variables would you use????
          When comparing PU magnets, everything else should be kept the same. Thus it may be a good idea to charge all magnets to be compared to a similar Gauss level.
          There is indication that magnet strength on its own has some sound influence.
            That is clearly the case - just forgot to put it into the list of variables. Several well-known pup makers advertise models with 'degaussed' magnets.
            I think that there are two effects:
            1. The interaction of the poles and strings changes and
            2. The small loop hysteresis losses vary with position on the demagnetization curve.
              The actual difference that is made is in terms of how much the pickups pulls on the strings magnetically. The effect can't be summed up with typical tone words because the changes vary depending on which position the pickup is in, and they vary by how far the pickup is set from the strings, and the changes differ by harmonic level. The string is divided up into harmonics nodes and anti nodes, and so the harmonic effects depends on how close the pulling force is to an anti-node, and how strong the magnetic pull happens to be. The more pull there is at an anti-node, the more that specific harmonic will be disrupted. The strong the pull, the complicated things get. Because there is so much change at different harmonic levels, it's almost more of a difference in timbre than it is tone, and timbre is much harder to describe, like describing the difference between a piano and an acoustic guitar.
                Also, it is how and where you strum relative to the turned on pickups(s). Guitars typically have a second harmonic peak for the first part of the initial attack and this can be controlled by pick thickness and picking style sort of like the subtle sounds made by speech and singing. Strings are just another type of vocal cord. Once the strings rotate from their initial horizontal motion through the strum, the strings will rotate to their normal motion and the initial second harmonic of sideways motion will get less as the string starts to decay.
                The only truly scientific way to test this is to automatically pick the string in the same place relative to the pickup and change pickups and magnets and compare the observable differences and then what you hear. String damping, even by a small amount, can be heard as a loss in sustain even if the pickup is not turned on.
                Joseph J. Rogowski
                  With all of the variables already discussed, it's pretty easy to recognize that any measurements taken would be questionable. Tone is subjective, but describing tone in it's basics isn't difficult. Describing in accurate terms the differences between Brand X, and Brand Z's A5 humbucker bar magnets wouldn't be so easy. Start with the hard data that you can measure. Take accurate measurements, and gauss readings. I'm sure there are some differences.
                    I appreciate the suggestions but don't think folks have a clear understanding of what I am asking.
                    I made some quick measurements on single isolated Alnico pole pieces that will address some of the comments. The pole pieces measure 0.187 (+/- .001) x 0.671 and have very different tonal properties. I have made a number of Strat sets (with similar winding parameters) from each material and gotten feedback on their tonal properties both professional and amateur musicians. At the present time the most skilled blues player I know (over 45 years of professional experience) has neck and middle pickups from each material in two hybrid (tele bridge and strat neck/middle) teles. He likes both, recognizes that there are significant differences in their tonal properties but is unable to describe the differences beyond saying that one of the materials "sounds more like a 57 strat" than the other.
                    My measurements show the difference in field strength between the two fully magnetized poles to be less than 5% and I find it hard to believe this difference to be large enough to account for the nature and size of the tonal differences between the two materials.
                    This conclusion is further supported by an experiment in which I added a 0.032 thick x 0.188 dia. unmagnetized disc of Alnico 3 to the bottom of one pole and repeated the field measurement. The disc had virtually no effect on field strength even though past experience has shown that attaching them to the bottom pole surfaces of a fully magnetized strat pickup will significantly alter its tone.
                    All the available experimental evidence (and I have accumulated a lot over the past 9 years) indicates that the tonal differences that are observed in samples of the same alloy from different manufacturers are due to variations in ferromagnetic loss. These losses also contribute significantly to observed tonal differences in the soft ferromagnetic materials that are commonly used to make humbucker slugs, screws and keeper bars. In all cases they are sensitive functions of composition, the methods used to cast the materials, and the details of their thermal and mechanical histories. Samples from different foundries vary significantly with respect to one or more of these parameters.
                    I don't think it is possible ( or reasonable) to measure the differences in ferromagnetic loss directly but do think it should be possible to describe their effect on pickup tone using reasonably precise terminology. Terms such as 'like a PAF' or 'similar to a '57 strat' get used a lot but have poorly defined meanings.
                      Very short answer?: no.
                      For the very good reason that nobody knows what those variables would be.
                      Dunno, you tell us, it´s your theory and investigation.
                      You don´t seem to have a clear understanding either, your question is still too vague and undefined.
                      Well, you say so and I believe you, and probably *listening* to them we could find differences ... or not .... but if not even you can describe differences clearly ..... what can we do at the other end of a screen?
                      Ok. If even such an experienced player, who *uses* them, can not describe differences, and to boot only by the vaguest most undefined and unmeasurable terms, what do you expect us to do?
                      And you want us to come up with 5 or 6 variables? Wow!!!!
                      Doubt that is the only difference and everything else is exactly the same.
                      Ok, keep experimenting.
                      Use different magnets: a whole one, another 90:10 , another 80:20 , and so on, make a table showing results, then make an hipothesis and verify it with further experiments. That´s the Scientific method.
                      [QUOTE]All the available experimental evidence (and I have accumulated a lot over the past 9 years) indicates that the tonal differences that are observed in samples of the same alloy from different manufacturers are due to variations in ferromagnetic loss.
                      Ok. so you do have a Theory.
                      Now experiment and confirm/discard/correct it. That´s the way to go.
                      Cool, now repeat experiments but show results in table form.
                      Otherwise it´s only light talk.
                      Hey!!! WHY not!!!
                      If it´s the basis of your Theory, then you MUST experiment changing that variable and showing results in a table form.
                      No "terminology" will ever be more precise than actual measurements, whth results shown in an ordered/compiled form.
                      You bet, and that´s exactly my point, glad you agree.
                      I suggest you continue with your experiments, and show results in an ordered way.
                        In a way, I actually see value in your blues player friend's feedback. Without any absolute measurement, tone is more efficiently compared than described. When mixing a track, you often see experienced sound engineers using an already mixed track as reference point, because they know that even their ears aren't a 100% reliable after listening to a work in progress many times. Some mixes aren't objectively harsh, they are only so compared to other mixes. One gets used to hearing certain types of sound, which is related to musical genre, what gear was available and what was fashionable at that time, etc. So in a way, your friend is giving you the most honest and accurate answer possible.
                        As for investigating the impact of using magnets from different manufacturer on the 'tone', as JM Fahey suggests, you would have to repeat the tests a few dozen times to get any results of scientific value, but there are still far too many variables to take into account, at least far more than six. You would also have to compare magnet samples from the each manufacturer with themselves to test the internal variations of their production.
                        This is all written from the humble point of view of a guy whose scientific background is that of a 'soft' science, ie. psychology. There are lots of guys here who come from 'harder' sciences who I'm sure will be more to the point. But in a way, the study of the human mind feels as slippery a terrain as that of tone. One can either look into a phenomenon with one's common sense & inductive processes, which are not without worth as they will be close to the thinking of the consumer, or study that phenomenon with a proper experimental framework, which takes time and resources. There is sadly not much value to anything in between those two and it can become very depressing to realize you've spent a lot of time, money and efforts on a biased experiment. We're not saying you can't do it, we're just saying that you need to do it very carefully and understand what such a study entails.
                          I am not sure about this. Is there any measurement data or literature supporting this? Generally the losses caused by magnets are very low, especially in relation to other causes. And the recoil permeability doesn't change much with charge.
                          But there are also other effects:
                          - Professor Zollner found that PU aperture is influenced by the field strength at the strings' positions. Higher fields shorten the aperture, which allows higher string harmonics to be picked up.
                          - I found that replacing the weak magnets (450G) in a P-90 type PU by stronger ones (700G) reduced the PU's inductance by over 10%.
                            You can have an absolute measurement in the form of FFT analysis, in a controlled setting. It's not that it can't be done, it's that very few people ever have done it. I've done some testing of this sort, and witnessed that magnetic strength causes variations at different harmonic levels, and that the differences were not linear, which is to say that when the magnet is stronger, you don't just get "more" of something, but entirely different effects emerge at different harmonic levels, depending on the degree of disruption caused by the magnet. At one extreme, the string ring naturally as if there was no pickup in the guitar, while at the other, you get "wolf tones" or "Stratitus", and then there is everything in between, which constitutes the various "flavors" you get with different magnets and different pickup height settings.
                              These observations are not solid enough to be actionable. In order to derive an objective conclusion from a survey, you need a lot more than one source of feedback, so that it can be said that what you conclude is true of many different people, and not one person. Also, if you're testing magnetic effects, it would be crucial that absolutely everything else is controlled, meaning the same coil is used, and the height of the pickup in relation to the strings never changes. In general, it is so difficult to assure that all of these things are accounted for that it's not merely enough to say that you have accounted for them, I'd expect a detailed description of the process by which you accounted for them. If you do none of this, then in all likelihood there will be some experimenter's bias at play, and I can only assume that the outcome you report is the outcome you had wanted from the beginning.
