LoZ pots and caps
Yes indeed this works. I found a 5k pot for the tone and with that a 2uF cap seems to work just fine. Using a 2.5k for volume, which works very well. I switched off the 48v phantom power too, and that did away with the noisy pots. Now the interesting part is how this all comes together when playing through the amp in a band. I find that the pickup is very good for soloing, although it is almost too bright at times. For rhythm it seems like it lacks the lower end punch of a hiZ pickup, but that is not a bad thing. To compensate I can just turn up the volume to where the low end is loud enough to be heard in the mix. In a low volume setting it really excels, as the full tonal range of the guitar can really be appreciated. This just confirms my opinion that if you just want to make a lot of noise, stick with a humbucker, since no one can tell the difference anyway.
Originally posted by Helmholtz
View Post
