Originally posted by EtLa
View Post
1022 rod...
Originally posted by Joe Gwinn View PostAuto parts stores sell an anti-seize compound intended for exhaust-system hardware that should work for this too.
BTW after the annealing process, I easily distorted this rod with my bare hand.Last edited by EtLa; 08-14-2008, 03:02 PM.
What type of cold rolled steel did you anneal and at what temperature? What kind of kiln did you use?http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostWhat type of cold rolled steel did you anneal and at what temperature? What kind of kiln did you use?Last edited by RedHouse; 08-15-2008, 03:02 AM.
Originally posted by R.G. View PostI took it to mean "highly permeable" or "high permeability".
http://music-electronics-forum.com/s...0&postcount=63
so many ideas you posted in that thread, did you ever do anything with them?
Why conitinue? For KNOWLEDGE. I try to learn as much as I can in the hope that something that may not seem useful when I learn it may click later on...http://www.SDpickups.com
Originally posted by EtLa View PostNext time I will try anti-seize because I needed to use a 6' extension pipe to unscrew the cap.
are there any high temp lubricants that would keep the threads from seizing?http://www.SDpickups.com
Originally posted by Possum View PostWhy conitinue? For KNOWLEDGE. I try to learn as much as I can in the hope that something that may not seem useful when I learn it may click later on...
Originally posted by Possum View Postare there any high temp lubricants that would keep the threads from seizing?
I suppose that one could wrap some paper around the pipethread before installing the caps. Do not use pipe dope for this, especially teflon dope or tape. The fumes from burning teflon are quite noxious.
By the way, if one uses galvanized anything for the pipe or caps, stay well away from the fire while heating the pipe assembly up to red heat the first time. And do this outside. Zinc fumes can make you very sick. For more information, google on "zinc fever" or "metal fume fever". It's better to avoid the whole drama by using only black iron pipe and fittings.
C1018
Carbon, C 0.15
Iron, Fe 99.001
Manganese Mn 0.7
Phosphorous, P 0.009
Sulfur, S 0.03
Chromium Cr 0.11
temperature? Don't know. The pipe was red for a good 2 hours and cool down for ~10 hours (it was still hot in the morning) so I wait until it completely cool down.
Sugar maple fire in a my backyard fireplace.
Nothing scientific, I know, but the rod is without any doubt really soft.Last edited by EtLa; 08-16-2008, 08:45 PM.
Pretty cool. Of course you know that when you bend it, that work hardens it so the annealing is lost, same with drilling or punching or machining it.
I wonder if just torch heating a small section and letting it cool in sand would do the same thing...http://www.SDpickups.com
Using a torch would build scale whereas if you limit the amount of oxygen in contact w. the rod, you can prevent scale build. Packing in charcoal in a pipe, lidded crucible etc. works well for this purpose, akin to casehardening, although you obviously want to slow cool for the annealing rather than quenching it to effect a hardened piece.
Edit: I just realized there three pages to this thread, not the single page I read. Most of this has been answered already, but I'm going to leave it in case it helps someone.
steel is real confusing, there is ASTM ans AISI then there are trade name alloys, I think half my brain melted researching iron and steel alloys this last year.
AISI classifies a material off of chemistry: 1022. 10 = carbon/manganese steel (max 1.00% Mn), 22 = 0.22 % carbon (nominal). The rest of the prefixes are here: http://en.wikipedia.org/wiki/AISI_steel_grades
ASTM classifies material off of material properties, and may have ranges of chemistry. Without A29 in front of me I can't pull off the exact material properties, but for example it may specify minimum tensile strength, elongation, and hardness.
According to http://www.suppliersonline.com/propertypages/1022.asp, there are easily a dozen ASTM specs that cover 1022.
What type of cold rolled steel did you anneal and at what temperature? What kind of kiln did you use?Last edited by defaced; 08-16-2008, 11:55 PM.-Mike
Originally posted by Possum View PostPretty cool. Of course you know that when you bend it, that work hardens it so the annealing is lost, same with drilling or punching or machining it.
With very-high-permeability nickel magnetic alloys, it is necessary to hydrogen anneal after forming to final shape.
