Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
Anybody here try Decker Tape No. 250 black ? Seems to have similar specs to old No.4 tape for thickness, strength and stickability. Worth trying? www.deckertape.com
Are we supposed to try and say that three times fast, without stopping?
Minimum order is 144 rolls at $1.40/ 60 yard roll. They say it impregnated with paint like substance for glossier look. They also say non conductive, but wanted to check with you guys.
I don't see any mention of paint? Yeah, someone call them, I bet you have to order a case of 500 rolls. Find out if it is conductive too.....bad
Depends on how conductive is conductive. If a turn is 100 ohms, it is not going to do much. The resistance has to be around the same as a turn of the #42 wire the coil is wound with to have a noticeable effect. A high-resistance tape can however act as an electrostatic shield.
I know they use conductive plastic for shields on some high end cables. That's an interesting idea for a pickup.
I ordered a sample....we'll see if it ever arrives....the granny sales rep was a bit confused as to whether I should contact the regional sales rep or whether she was going to send me the sample.
They are actually not that far from me. I wonder if I could go there and look at samples?
