Hey guy's. Looking for some inputI am wanting to build a hi output pickup 15.9k range with a alnico 5. I am guessing 44awg or mabey 45awg ? and I was wondering how many winds will get me there. I just can't figure out that darn calculating chart for pickup building.. It drives me crazy
Need Advice Hi-Output pickup
Originally posted by JCrab View PostHey guy's. Looking for some inputI am wanting to build a hi output pickup 15.9k range with a alnico 5. I am guessing 44awg or mabey 45awg ? and I was wondering how many winds will get me there. I just can't figure out that darn calculating chart for pickup building.. It drives me crazy
JesseJames was getting that with 8000 turns of 43.
You definitely don't need 45 for that.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
T
Originally posted by JCrab View PostThanks T. When you say 6700-7000 is that each bobbin or a starting point, if a starting point would you have more winds on the slug or screw so to speak.. Oh and by the way the wire I was tracking on the bay turned out to be Reminton
I just buy straight from remington, but they do sell on ebay.
It seemed like the shipping may have been a few bucks cheaper if you bought direct.
Something like that.
I would just wind them 7k turns each coil.
Then read them and maybe peel a little off of the screw coil.
Good Luck,
TerryLast edited by big_teee; 07-12-2012, 06:38 AM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by JCrab View PostThanks, Is this what I am looking for, I found it at remington, Enameled Copper Magnet Wire - 44 AWG - 5.55 lbs Solderable 155C MW-79-C Red
The Coil Estimator from Salvarsan is pretty easy to use, gets close, and I use it all the time.
http://music-electronics-forum.com/t28111/www.sonnywalton.com
Originally posted by SonnyW View PostFWIW I just did a single coil sized HB with that same wire from Remington and 5750 turns per bobbin and it came out 13.4K.
Originally posted by JCrab View PostThanks SonnyW, the pickup estimator confuses me
you should always pay attention to what numbers you decide to go with & what dcr you end up with , I always come up a little short when using the estimator so I add some winds to acheive a certain dcr"UP here in the Canada we shoot things we don't understand"
Originally posted by copperheadroads View PostIt's pretty simple once you play around with it ,Select the type of pickup bobbin,(Stewmac 50 mm humbucker I think it is) wire gauge & then desired resistance
Originally posted by JCrab View PostI think I am doing something wrong,, I just came up with 5904 winds of 44awg,, that does not sound rite to get 15.9k
That was for 44 ga single build wire.
The bobbin I chose was for a 50mm Paf.
Terry
It seems to me a better way to think about this is:
1. How many turns of #42 can I fit on? Well, that number is probably not enough based on experience so...
2. How many turns of #44 can I fit on? Well that number might be enough, so let's wind it full. OK that has plenty of output, but it is a bit muddy. Let's try it with 5% fewer turns, and see how that sounds, etc.
Or, if #44 did not give enough output, then you might have to try even smaller wire.
You are going to find what the trade offs are.
