The last 3 gtar shielding cavity jobs I've done ,I've used Aluminum foil & only used a small piece of copper tape to solder the grounds to & stick the copper foil & grounds to the Aluminum tape .
Then I've check for continuity & it was all grounded . it really cut down on noise compared to that crappy shielding paint & as very economical as you can buy the aluminum foil at any hardware store .
