Originally posted by big_teee
View Post
It's really weird, because the starting hookup wire seems to covered with the coil wire.
So i'm pretty sure, that it was hooked before the winding.
The starting point of the coil wire comes out on the upper side of the bobbin, in the middle on the longer side.
Maybe they hook the hook-up wire trough the hole, and strung it to the side, before starting to wind.
The soldering could be made after winding: there ist about 2inch wire from the starting side left under the covering tape left.
