Hello, I am new to making humbuckers. I've made maybe 5 or 6 so far. I just need some peace of mind that I'm wiring them correctly.
They aren't sounding as powerful as I think they should be, so I want to completely rule out if it's an issue with my wiring.
I have done some research but I still get confused when I see people's pigtail leads coming from opposite sides of mine, and the nomenclature of Reverse Wound vs Reverse Connected.
So anyways this is exactly what I've been doing,:
![HumbuckerDiagL.JPG Click image for larger version
1. Both Slug and Screw bobbins are wound in the same direction on my machine, the bobbin is on the right side of my machine spinning away from me.
2. I'm using black pigtails for my "starts", and white pigtails for my "finishes"
3. I'm wiring South Start (black screw side) to Ground
4. South Finish (white screw side) to North White Finish (white slug side)
5. North Black Start (black slug side) to Hot
If someone could just let me know if this is correct, I would greatly appreciate it.
