Chinesse coil winder..?
  • Chinesse coil winder..?
    I looking for a winding machine, and I found those at ebay. They are made in China. They are cheaper than Shatten's winding machine....
    Does someone has a similar one.. or what about quality...?
    Auto Motor Coil Transformer Winding Machine Winder 110V - eBay (item 280358707446 end time Jun-25-09 05:40:30 PDT)
    Programmable Coil Winding Machine Winder Variable Speed - eBay (item 270407276022 end time Jul-11-09 18:54:14 PDT)
    jairo eduardo suarez gallardo
    mm basses -only exotic woods from Colombia-
    mm basses
    We've talked about these before.
    "Max. Coil Diameter:70 mm"
    That might be a limitation to a bass maker since a J bobbin is already 92mm long.
    I don't see what is limiting the max diameter but I would want to ask about that before committing to it. Maybe they are confusing Diameter with Radius?
    You will also need a larger pulley on the main spindle since the slowest speed is 500-800 RPM and the top speed is a whopping 4500 rpm
      Which is the recommended speed for a pickup winder..?
      thanks.
      mm basses
        Does someone knows an economic pickup winder..? where can I buy it..?
        mm basses
          Jairo,
          We talk about these things here all the time!
          Most of us have made our own winders or bought some antique and a few have bought the Shatten winder from Stewmac.
          I think these Chinese winders look like a really good deal and will probably do what you want. Electric Davy boy has one I think so you should ask him about it.
          You will still need a faceplate for it so either make your own or pay a local machinist to make one for you.
          I have made 4 faceplates and they are very easy for me now. I use a compass to draw a circle on a sheet of plywood (I like the russian birch ply). I cut that circle out on the bandsaw and then sand it on the belt sander until it seem round enough. I drill the center hole to match the O.D of a drill depth collar. (A metal ring with a setscrew.) You'll want to find out the shaft dia and then buy or make a bunch of collars for your faceplates.
          Since the shaft on the winder is too long you'll want to cut it shorter because you don't want to have to drill such a big hole right through the middle of all your pickups to let the shaft pass through.
          A speed range of 200-2000RPM should be plenty. You can just pull the small pulley off the motor and let the belt ride on the motor shaft to slow the winder down.
          casinolevant levant casino
