Counters from Advanced supply
  • Counters from Advanced supply
    I have been researching counters and trying to get a handle on what works best, saw these and wonder if they would work ok.
    Bill
    http://www.canadianbreed.ca/
    http://www.canadianbreed.com/
    www.facebook.com/Canadianbreed
    www.youtube.com/user/Bobo9977
    Impossible to say. Datasheet required.
      Most likely discontinued and been sitting on a shelf 5 years, something similiar http://www.kep.com/catalog/ii/pdf/kal-din.pdf
        If the internal lithium battery isn't exhausted, this ought to work as a turns counter. It's similar to the CUB3, but with a few more options.
          Speaking of expired batteries, I got a couple CUB4's once that had dead batteries, I opened them up with the intention of replacing the batteries but instead just ended up removing them and hooking up a LM317 setup for 3.3V output.
          -Brad
          ClassicAmplification.com
            That'l work, if the dead batteries didn't leak.
              Try the intersil 7207 single chip counter. add a 4 1/2 digit display and instant
              counter. It is still available from several sources for a few bucks, I got mine as a free sample. Very easy to use you can cascade two for very high counts. use a phototransisror led interrupter or reed switch to trigger.
                Looks like a Red Lion cub 3. Probably work fine.
                www.chevalierpickups.com
