I'd say if it isn't bouncing then it isn't bouncing. It seems like it would be pretty obvious if it was. A weak spring does seem like it would work better - my many hours dealing with strat tremolo springs tells me that weaker/worn out springs have a poorly defined zero which seems like it may avoid the resonance thing.
I should learn how to work with acrylic more. I generally use hardwoods, but the acrylic just makes better sense for pickup gear... flatter, clear, drills straight... I get way too excited about all the wrong things sometimes.
