There are all manner of fine wire tension meters available that clamp onto your wire and tell you either on an analogue meter or digitally what your tension is. They can measure from 1 gram and up. I can't figure out what they cost but they are pretty simple looking devices you could make yourself. They work by pushing on the wire running between 3 small pulleys that are spring loaded. You could use this to set and check your tension through the felts. One problem is undoubtedly that your tension is constantly changing as the wire get pulled faster or slower over the ends of the bobbin.
Tensitron - Products - Fine Wire & Filament Tension Meters
ZEF / ZED Economical Digital Tension Meter
