Anyone using the Syscomp CGR-201, this is the newer model. I can get plots of pickups, somewhat, but sometimes it cuts off when it hits 0db level, then after it stops it adds the +20db scale. Here is a regular plot, probe A 1x, probe B 10x.
Here is when it cuts off and stops.
Even if i turn the level down, whenever it crosses the 0db point it stops.
Also, the "save plots as reference" or " show reference plots" does not work, i get some error
can't use non-numeric string as operand of "/"
while executing
"expr {$::net::leftBorder+log($temp/(pow(10,floor($net::startValuePow))))/log(10)*$decadeWidth}"
(procedure "net:
lotRefMag" line 42)
invoked from within
"net:
lotRefMag"
(procedure "net::toggleReference" line 4)
invoked from within
(menu invoke)
Also have a bunch more questions, doesn't save all settings(only some), probe capacitance drastically changing the peak freq, how to edit tcl language file etc.etc.
while executing
(procedure "net:
invoked from within
"net:
invoked from within
(menu invoke)
