signal gen?
  • signal gen?
    Does any one know where to find a signal generator program for running on PC.?
    just a 1khz sine wave would suffice!!
    Thanks
    i think there is one on duncan amp tools. i downloaded it but havent tried to use it, as i havent made a probe to attach. when i do make a probe, i will make sure to put a cap on the hot side, to ensure that accidentally probing something with dc on it
      I've been wanting to build a signal generator from an old casio mini keyboard
      the flute setting is a pure sine wave
      ted weber sells small transformer (less than $5) for making a line out you can plug into the headphone jack
      the volume control will give you amplitude
      and you have your choice of frequencies
      Ray
        Attached is a 1kHz sine wave mp3. It's about 10 seconds long so use your computer/mp3 player's loop function for testing.
        -Mike
          Cheers man that's a great help!!!!!!!!
            Hmmmm. my last post disappeared....anyways, i don't know what kind of A/C voltages to look for at the various points. I can tell you what i checked so far with the master all the way up
            speaker out: 7VAC
            EL34 grid: 75VAC
            Master vol out: 2.5VAC
            tone stack in:47VAC
            any clues there?
              Well, 75VAC at the grid should be enough to drive the power tubes pretty hard. But 7VAC across an 8 ohm speaker load is only about 6 watts. So something doesn't add up there.
                Thanks
                I have one, but I'm not sure how to post it for downloading. If you'll email me, I'll send it to you.
                Ted
                at webervst dot com
                  http://zeitnitz.de/Christian/Scope/Scope_en.html
                  pc based dual trace osciloscope AND a stereo programable signal generator with sine square and triangle outputs
                  I forgot all about this program
                  My son uses it to "super tune" his guitar
                  has a lot of nice features on it
                  Ray
                  ************EDIT***************
                  I just downloaded it onto this computer and it seems to work with VISTA
                    Has you son checked out G-tune? It's shareware, but well worth the nag screen - especially for intonating.
                    http://www.jhc-software.com/gtune.shtml
                    -Mike
