speaker 8ohm help
  • speaker 8ohm help
    Hi all,
    I have an 8 ohm speaker and I'm trying to figure out how to make it work!
    I tried to plug it into a simple amp circuit that produce a 0.1V as output on the speaker end. unfortunately...it doesn't work!
    any suggestion? I thought that an 8ohm 0.1W speaker was perfect....I'm quite sure there's something that Im completely missing here!
    thanks!
    Try a battery to hear a "plop" sound. If not, the speaker is dead
      thanks carlitz but the speaker works! any other suggestion?
        The question is, what is the circuit you are using to try and drive the speaker?
        WHich is it, .1v or .1w?
        casibom< giriş/a> betturkey
