Article about Stereo Shuffling application
  • Article about Stereo Shuffling application
    Hi,
    I just wrote an article about the stereo shuffling.
    "Joel-Aimé: (ENGLISH)Usefulness of M / S during the mixing and mastering stage 1: Shuffling stereo. -------------------- (FRANÇAIS) Utilité du M/S (CE/CO) lors du mixage et du mastering 1: Le Shuffling Stéréo.
    It is in English and French.
    It is a poorly documented topic over the Internet, the most recent article I found dating from 1983.
    I am looking forward for any suggestions that could improve it.
    Thank you for your attention.
    M/S processing is quite widely used and lots of DAW plugins support it. If anything, looking for information on the Internet is a namespace issue. Search engines ignore punctuation, so when you type M-S, M/S or MS into a search engine, it thinks you mean Microsoft.
    Try "mid side audio processing" as a search term.
    And, many people probably use M/S equalization without knowing that it's called "stereo shuffling". I certainly didn't know that, although I'd used it before.
    I'll raise you 1986.
    http://www.audiosignal.co.uk/Resourc...uffling_A4.pdf
      You are right, my bad, i thought that article was from '83.
      I mention this article in my bibliography.
      It is really interesting and complete and serve me well at the start of my experimentation on Shuffling.
      I really recommend it for anyone interested in that matter.
      marsbahis betturkey
