On an ending note, The 39095750 OTA adaptor assembly that I got from Peavey worked well.
It replaces the peavey 87478 or 787478. I did reverse engineer it to see what makes it tick so I have a schematic of it should someone want to make there own.
However, the $15 peavey charges for the unit is a good deal.
It comes with an 8 pin plug to plug into the existing socket. The PCB has a 2 channel OTA chip. only one channel is used. the other is set for unity gain and is basicly disabled.
I'm sure this was done to prevent noise.
