Buffered Wah Pedals
  • Buffered Wah Pedals
    Why must companies insist on doing this!? All for the sake of skimping on a DPDT switch for true bypass...doesn't a DPDT version of the same switch cost roughly the same as the SPDT switch they use?
    It is my personal belief that the way the wah circuit input loads your pickups when the wah effect is engaged is just as much a part of the classic wah sound as everything else in the circuit...when you buffer it you take away from that.
    I've always hated Dunlop Crybaby wahs for this exact reason and have always used the Vox reissue wah as they've always stayed true to the original circuit. Well I just bought a brand new Vox wah to replace the one I had that got ripped off a few years ago with the rest of my gear and now apparently Vox is now buffering the input as well!
    WTF...just put in a damn DPDT switch and call it a day!
    Jon Wilder
    Wilder Amplification
    Originally posted by m-fine
    Originally posted by JoeM
    Such it is with many things. Sell the new one and buy a used older one on Ebay. If anyone even looks at it poke 'em in the eye with your finger.
    Chuck
      Ha - it just goes to show. I've been getting frustrated with my crybaby losing effectiveness when I patch a fuzzface after it, so realising that the low input impedance of the fuzz was shunting the collector resistor of the crybaby T1, this weekend I buffered it with a common collector, with it's base linked to the T1 collector, 10k emitter resistor to ground, with the emitter feeding the output and pot. It seems to work well, though I had to bypass the T1 collector 22k with 220pF, in order to damp down some MHz oscillation that subsequently popped up at the bass end of the pedal travel.
        That's the problem with unbuffered wah-wah pedals, you can't use them with some other pedals. Fuzzface after wah is the prime example.
          I'm talking about wah pedals that have a buffered INPUT...not output.
          Jon Wilder
            OK, you think the wah's loading of your pickups is part of the sound. SOmeone else may think loading his pickups is the whole reason NOT to buy some models. Apparently both versions exist, so both you and those other guys can get the kind you prefer.
            SOme guys think chili needs beans, and other guys think beans do not belong in chili. SOme guys like to look at skinny girls, and some guys like to look at plump girls.
              The fact that you even thought of this as a reference tells me your not in the "super model" camp. Those girls are built like nine year old boys. Someone should tell 'em to eat a sandwich (and keep it down).
              I'm with you BTW. Give me a woman with curves. I had my share of skinny little girls in high school.
              Trying to keep on the subject. Has anyone looked into mods for reversing this? Sounds like it would be easy enough, as pdf64 found. But there must be CryBaby mods around for both new and old models.
              Chuck
                I've modded several Crybabys via bypassing the buffer. The problem with the Vox is that most of the Vox circuitry is all SMD. That and I think some of the circuitry isn't the same as the original either.
                Jon Wilder
                  I have an older "Hendrix" Cry Baby. I think it's supposed to be more like the Vox. Long ago I
                  changed some caps and resistors to give it more umpf in the low pedal travel and an overall better mid character. I can't even remember what I did so I'm glad I still have it 'cause it sounds great. I haven't had any trouble with it effecting my tone when switched off so I guess mine isn't one of the buffered offenders. No SMD in mine either. AFAIK there are schems available for the original Vox pedal. There's so few part's in these things I've thought about building my own in an old broken Dunlop I have laying around.
                  Just thinking out loud.
                  Chuck
                    Here is one from 1967
                      Here is another one I found time ago and decided to share : http://music-electronics-forum.com/t13720/
                        Wow...that 100K resistor across the choke should make for a pretty agressive wah.
                        Jon Wilder
