Alps Tact switch availability
  • Alps Tact switch availability
    I've used the ALPS SKHVBE tact switch for years to replace switches in Roland gear (and others), but I just went to order a 100 of them from Mouser and they're discontinued now. I've only found one possibly suitable replacement, that being the Omron B3F-6022, but I seem to recall that these didn't always work precisely right in Roland gear (the actuator sits a little higher, even though it specs the same).
    Anybody run into this yet, and how did you solve it?
    The switch is a 6mm x 6mm tact switch with a 5mm actuator height. There are plenty of those around, but this one only has 2 leads instead of 4, and is through-hole.
    Thanks for any suggestions.
    BK
    BK
    You can replace the SKHVBE tact switch with the SKQKAB one manufactured by ALPS
    (Roland p/n is 01780101 or 02891789).
    The SKRGAED010 or SKRGADD010 (Roland p/n is 02891789) tact switches also may
    be used as a good replacement - the only difference is a round body instead of rectangular.
    The TL59AF160Q switch manufactured by E-Switch is a direct replacement as well.
    Good luck,
      Thanks for the info!
      I had already ordered the Omron B3F-6022 and they worked fine as well.
      Thanks again.
        You didn't mention whether 2wire or 4wire. I just ordered 75ea of these 2wire versions with measurements that match yours from Mouser:
        2 wire 6mm x 6mm x 5mm = 101-TS7311T1602-EV maybe that's why they have none left ;-]
        Nice thing about Mouser as you undoubtedly know, from Roland or Korg these little buggers are 2.50ea. Mouser...ususally like 12-18 cents ea. When you're replacing 20-40 of them on one keyboard, that makes quite the difference. glen
          Yes, these were the two lead version. I simply can't bring myself to order them from Korg or Roland...just WAY too expensive!
          Did the Mountain switches work ok, or did you get them yet?
          Deneme bonusu veren siteler
          betticket istanbulbahis
          casinolevant levant casino
