Acoustic/Electric Guitar Output
  • Acoustic/Electric Guitar Output
    I'm wondering what the signal output of an acoustic guitar with a built in pickup/pre-amp typically is in terms of impedance. Reason I'm asking is I'm wondering how best to plug into a PA system with it - direct into the PA or through a direct box which converts a high impedance instrument signal into a low impedance signal for input to a PA?
    Thanks,
    Greg
    You did not specify the circuit.
    Generally, an active preamp output will be a low impedance.
      It's the B-Band A3T circuit found in Simon and Patrick (one of the Godin brands) guitars. I thought the output would probably be low impedance but wanted to be sure.
        Jazz P Bass is right.
        Correctly designed (professionally designed – always) pickup preamp has very
        low output impedance and may be connected to input with any impedance.
        The issue is only sensitivity of the input.
