fender champ 12 overdrive ch issue
  • fender champ 12 overdrive ch issue
    hi gents,,,
    i have a fender champ 12 ,, loverly little tube amp, my issue is that the clean ch is fine,, when i change chanells via footswitch,,the distortion chanells volume and gain are max,, the distortin chanells volume pots have no effect!,, ive had it for about six mths,, any ideas would be greatly appreciated guys!`dodgy optocops?
    mmmmm thanks in advance!
    Originally posted by T-bone View Post
    hi gents,,,
    You likely need a pot job. And I mean potentiometer.
    Valvulados
      The issue very well may be in the LDR.
      Do you have the schematic?
      Do a few ohms/ voltage checks at the LDR.
      Compare them to the one that works.
      The pots can be checked for proper function with a meter set on ohms.
        The pots can be checked with an for proper function with a meter set on ohms.
        the pull/push treb/mid pot is faulty! by ldr i assume you mean light dependant diode?
        btw new pots have been installed inthe overdrive chanell and have tested as working,
        i will try to upload scematics for you soon! never done uploading before
        thanks in advance guys
        x
          Fender Champ 12 Schematic
          The LDR is a Light Dependent Resistor.
          The signal goes through both V1 & V2 on both channels.
          What is being switched, by the LDR's, is the channel volume pots & R18 & R20.
            What exactly does a pot job consist of? Is it a test of the resistance of each pot, a generic cleaning, replacement of all pots...? I'm having a similar issue with a fender 1000 roc pro. I'm new to the amp building/repair game, so layman's terms would be appreciated! Thanks!
              Welcome to the place. All of the above could be considered a pot job. What is specifically your problem?
