Hi there all,
I was wondering if someone could have a look at a rough plan I drew up for a guitar routing system.
The idea:
-The Guitar is plugged into the pedal
-The first switch decides whether it is sent to the amp's input (in which case the amps FX send is tapped to bring the signal back to the pedal after the amps pre) or to a external preamp.
-The second switch is just a normal channel switch for the amp.
-The third switch decides which of 2 external preamps the signal goes to.
-The fourth switch decides if the signal (whether fed back from the amps send or from the output of one of the external preamps) is passed to the amps power section/FX return (via the sixth/mute switch) or fed through a series FX loop before hitting the mute switch
-The fifth switch is just to operate the boost function on the amp.
Clear as mud?
Does my schematic reflect that/would it work?
What do I do with all the earths from the various connectors? Just connect them all together and work only with the signal wire?
Thanks in advance
The idea:
Clear as mud?
Thanks in advance
