I found out they make that cap in a chassis mountable aluminum case. Hapiest day ever.
Has anyone used ARS 500v electrolytic caps?
Really? Do you have an online supplier for those? May be my happiest day ever as well, because that is precisely what I was looking for recently!
Originally posted by diagrammatiks View Postpercyaudio sells the 100uf ones. partsconnexion has the 50 and 100uf.
I just checked both catalogs and found them. The 47uF ones are 52mm diameter, the 100uF is 64mm x 114mm, that's one heck of a large capacitor, I don't even have clamps for it in my poor man's stock...
Haha I know right. They are huge.
Although I used the ASC motor run caps in a build and with a little planning they were alright.
I grabbed a bunch of clamps in anticipation though. Steve from ApexJr sells 2 inch + clamps for like a dollar each.
At any rate...sure beats trying to fit more then one of the 47uf inside the chassis.
Originally posted by diagrammatiks View PostYa, I mean I just started getting into building recently but everything I've read makes me not want to use electrolytics caps ever for anything. So I've been doing a lot of research on alternatives.
Yeah, the voltage is frustrating. Unusable in most tube projects. I still don't understand why Sprague continues to make 350 VDC caps.
The automatic translation on their site are a bit frustrating...
Chuang Ge Electronic Industrial Co., Ltd.
"Import metallized film winding without a sense of style" WTF?
"Is mainly used for inverter, inverter, inverter, as well as induction heating equipment," - I guess if you invert 3 times you end up inverted?
Originally posted by diagrammatiks View Posthow'd you mount those?
Those are two Solen 47uF x 630 V caps. It's not the most beautiful setup, but I solder the terminal strip to the chassis and the caps to the bridges. At 52 mm diameter they're not quite a beer can, but pretty darn huge for 47uF.
