Failed 1/4" jacks?
  • Failed 1/4" jacks?
    How often do you encounter 1/4" jacks on which the plating of the barrel has failed completely?
    I just worked on a guitar with a reported flaky output jack. I was expecting to find the usual broken signal wire, but what I found was that the barrel was completely oxidized. Once I'd cleaned off the oxide, all that was left was bare brass--no plating. This was a late-70s, made-in-Japan jack installed in an Electra Omega guitar.
    I replaced the jack with a new Switchcraft calculating that the brass might oxidize and make the problem return.
    The interesting part was that this guitar was reportedly stored in a closed case for about 15 years, and the guitar itself looks brand-new.
    Run into that fairly often here in the USA Pacific Northwest. We have a mildly marine climate, and a lot of things oxidize that probably wouldn't in a drier inland area.
      If you look at a lot of mil-spec phone plugs and telephone company plugs, they are brass with no plating to begin with.
        Yes they are, and they used to have a special cleaning kit which essentially was no more than jewelers rouge with thick pipe cleaners and polishing cloths.
        John R. Frondelli
        "Mediocre is the new 'Good' "
          Hah.
          Music equipment gun cleaning kit.
            Yup. I've seen it on a lot of old jacks. And other brass plated hardware like pickup covers and bridges. Mostly on Japanese guitars from the 70's. The plating on the brass is of such poor quality and prone to oxidation that I've wondered why they put it on there. Bare brass would have been better. If not ideal.
              I like stereo jacks with the "sleeve" contact as ground; it makes better contact than the barrel usually
              except for these cables
              some peoples sweat has low pH and corrodes VERY quickly
                Originally posted by tedmich View Post
                I like stereo jacks with the "sleeve" contact as ground; it makes better contact than the barrel ...
                I often do the same thing, usually with guitars. The other fringe benefit is that the additional contact hold the plug better in the jack.
                John R. Frondelli
                  I also always use stereo jacks with mono stuff.
                  *Only* problem it that (relatively often) guys plug halfway and stop (they feel the click) and then complain of "no sound".
                  Oh well.
                    Oh well.
                    IMHE the average guitarist isn't the sharpest pencil in the drawer.
                      I do the same! It means I can buy a big heap of the same Switchcraft stereo jack, and use them for TRS balanced line, guitar pedals, guitars and amps.
                        Oh well.
                        Tell them to think of it more like sex, and they won't be pushing it halfway in, even if they feel resistance.
                        John R. Frondelli
                          jack/plug discussion sexual innuendo limit EXCEEDED
                            In, out, repeat if necessary. I see the connection.
                            casinolevant levant casino
