Does anyone have a schematic to a boss ge7. I would like to see if I could convert it from ac to dc.
Convert boss pedal ac to dc
Not sure what you mean. As far as I know, the GE-7 Boss EQ pedal runs on a 9v battery or a 9v DC adaptor.
WHat exactly are you trying to do to it?
Google "boss ge-7 schematic" and the schematic image pops right up.Education is what you're left with after you have forgotten what you have learned.
ANy chance you have a schematic link?
If it ran off the 120vAC, then they didn;t have to worry about keeping power drain low, so that may be a factor.Education is what you're left with after you have forgotten what you have learned.
The old Boss GE-10 was ac mains powered.
From the schematic it runs on + and - 13v .
As it is a split rail supply the easiest I could suggest is 2 x 9v batteries but
1. They may not last very long
they didn;t have to worry about keeping power drain low (Enzo)
If it is, indeed, made to take AC, but can also run off a battery, one need only connect the adaptor jack to where the circuit draws power from the battery.
If, for some reason, it ONLY runs on the AC adaptor, and doesn't run off a battery, then one would need still need to somehow bypass the rectifier circuitry that takes the AC providedby the adaptor and converts it to a suitable DC voltage.
haviong said all of that, however, you should probably read this before making any moves or changes: ?????????????
