A linear power supply just means one that isn't switched mode.
The "linear" part originally was the regulator stage which would run as a linear amplifier, basically starting with too much voltage and using a transistor as a variable resistor to throw away the excess. In contrast to a switching regulator which chops the transistor on and off, creating a series of pulses that average out to the desired voltage.
One advantage of a charge pump is that it doesn't require an inductor. I'd feel uneasy about using inductors with high frequency currents pulsating through them, right next to guitar pickups. At least HF magnetic fields are easier to shield against than line frequency.
