Source of NEMA 5-15 panel mount receptacle
  • Source of NEMA 5-15 panel mount receptacle
    Hi all. I recently picked up a 240v -117v step down transformer. It's a beast of a thing. But the 117v outlets are two pin with an outboard earth connector. Does anyone know where I can source a 3 pin socket to replace the older style receptacles? Please see the attached picture for a look at what needs to be replaced.
    Many thanks
    JeffClick image for larger version
    It's not microphonic - it's undocumented reverb.
    Most these days are square snap-ins.
    But...
    Hubbell Wiring Device-Kellems - HBL5256 - Electrical Connectors - Connectors - Allied Electronics
    http://www.alliedelec.com/images/pro...S/70116155.pdf
    Such connectors have been stupid-expensive for some time now. I used to sometimes see them as replacements for the ones on the rear panel of Fender amps, so some amp supplier might still have some.
      Edison 15A 125V Female Chassis Mount Connector 5 | eBayEdison 15A 125V Female Chassis Mount Connector 5 | eBay
      5 for the price of one?
        Another approach is to use a 2 blade to three prong adapter with the short grounding conductor wire that could be attached to the outboard earth connector. Photo example attached.
