Help needed with building a JFet-Matcher
  • Help needed with building a JFet-Matcher
    Hello to everyone,
    in order to build some phaser effects, I started to build a jfet-Matcher, but the da.... thing doesn't work and I can't find the error.
    I attached my drawings to this post.
    I copied this circuit:
    Testing and Matching JFETS | Stompville
    I didn't used a etched pcb, build on tagboard and wired the 3-position switch seperatly to the circuit.
    For power supply, I used a print transformator ( 2x 9V with 0,75VA), followed by 2 rectifier circuit including voltage regulators, one circuit supplies the two digital meters ( Volt & Ampere, they light up), the other the jfet - circuit.
    The connection from C to Pin 1 is soldered at the 3-position switch, the coloured dots in my drawing are the wires to the switch.
    I twice checked all the soldering points,checked all the connections, tested the opamp, and used the multimeter to measure the voltage without plugged-in opamp/meters.
    Everything looks fine, the only thing I'm not sure about is the voltage on (opamp-)pin 3: the multimeter only shows 0.98 volts.
    Am I right, that resistor R1 and R2 are used as voltage divider ? So theoretically, it has to be 4,5 V ?
    The original circuit also shows on the very right bottom a soldering point to ground - do I have to connect this ? (the enclosure is of plastic and the 230V power supply is without groundwire)
    The last idea I have is that 0,75VA (AC) from the print transformator might not be enough to make the jfet-matcher work..
    I'm thankfull for every tip or help
    Best regards
    Gokarna
    Original schematic added
    Hello,
    No idea from anyone here, where the problem is ?
    Or did I start this topic in the wrong category ?
    Below, you can find also the original schematic for the jfet-matcher from Stompbox.co.uk.
    Any comment is welcome.
    A nice weekend to all of you,
    Regards
    Gokarna
      Don't confuse the 'GND' symbol with Earth Ground.
      It is simply a label.
      Pin 4 of the opamp should be connected to the 'Battery Minus'. (which can be considered 'Ground').
        Germans complicate things
        Just build the *original* circuit, without multioption selectors, ampere meters, etc.
        That's all you need.
          Hello,
          thank you very much,Jazz P Bass and J M Fahey for your comments.
          It is, the "Jumper" (see my drawing) connects pin 4 & 5 with battery minus/ground.
          Yes, you might be right . I liked to build this special jfet-Matcher also for the pleasure of building a nice device.
          Just build the *original* circuit, without multioption selectors, ampere meters, etc. That's all you need.
          Would be an alternative. But not satisfying im my case. I would like to know/learn something more about electronics, even I'm stuck now.
          So "Germans like complicated things", if you like.
          Any other Ideas, whats wrong with my built ?
          Best regards
          Gokarna
