It's a small 5x20mm fuse, fast blow, and it says on a sticker in the amp next to the fuse "0,16AM". I assume it's a .16 amp?
what fuze value is this?
Probably, but apply a little educated guessing: if it's in a small 1 tube preamp, or an SS pedal, 0.16A`looks fine; if it's in an Ampeg SVT Classic or a big rack power amp, I'd read it as 16A and think that the "dot" is just a small metal imperfection.
So .... where did you pull it from?Juan Manuel Fahey
May not be the mains fuse either. could be for control voltages or some such. Still... just guessing without model # or schematic.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostMay not be the mains fuse either. could be for control voltages or some such. Still... just guessing without model # or schematic.
0.16A fast blow is too small for any power tube; at most it would be enough to protect a screen supply .
Weird anyway.
Try to sketch at least a part of the circuit where it's located.
Another option might be that the original fuse was, say, 0.5A , and user replaced it with a 0.16A he had available , which of course blew instantly.
FWIW I never believe users when they swear on a pile of Bibles, Qurans or whatever that "they touched nothing and everything is factory original"Juan Manuel Fahey
