Hi guys,
I apologize for opening this subject in this subforum, but I didn't know where else to ask for help.
I'm in the middle of repair of two OttLite desk lamps. Both have same problem, burnt two transistors and a few resistors in electronic ballast (invertor).
I was able to find data sheet online, but couldn't find original transistors BJT 100S.
Instead I ordered switch mode transistors MJE13007 from Digikey, these have similar parameters and they are rated for higher voltages, higher current and more power.
After replacing it, lamps are just at the threshold to fire, they are starting but can't light fully.
I have played with different values of capacitors and resistors, there was no change.
Could you, please, let me know what I overlooked, circuit is simple, if you know right replacement parts I would appreciate your help.
Thank you in advance, Damir
DSASW00169912.pdf MJE13007-D.PDF
P.S.
Problem was caused by bad fluorescent bulb, when first stopped working, I tried the bulb in other lamp
P.S.
