HELP! battery disconnect POP!
  • HELP! battery disconnect POP!
    I have a customer bass that has the fishman Power chip Preamp and regular passive pickups. Problem is the fishman for the piezo has low battery life (it the way they are). So , I tried to make a bypass switch for the battery when the magnetics are on and switch the battery off. ( to save battery life) BUT it POPS way too bad when selecting the piezo back on. Any ideas? where to put a cap or a pull down resistor?
    If you are switching he full power on/off instead of some audio signal, the pop is practically inevitable.
      That's what I'm afraid of :/
        What about using a pot with a rotary switch with built in. It could possibly be wired to turn the piezo signal off on the way to turning the power off. I'm not sure if a pot like this would work for you or where you would get one. There is an Artec amp kit that CB Gitty sells which uses this setup which I have built into cigar box guitars.
        https://www.cbgitty.com/amplifier-ki...e-wired-leads/
        Drewline
        When was the last time you did something for the first time?
