amek 9098 stepped to pot gain control conversion
Originally posted by angelothewolf View Postreverse log? what value?This isn't the future I signed up for.
Originally posted by angelothewolf View Postwell I try a 10k reverse log and it worked the same way. in the last millimiter of pot travel came a lot of gain sudently. Im taking the signal right after the 4700uf caps and ferrite "F9"This isn't the future I signed up for.
That would lower signal to noise ratio to worst than Behringer level. The key for pro console signal chain is each stage operated at its optimum DR and gain in series.
The front end is using the common mode gain reduction as it is, which is needed for optimum balanced line operation. That common mode shunt is why the low values are used in the gain switch.
Originally posted by km6xz View PostThat would lower signal to noise ratio to worst than Behringer level. The key for pro console signal chain is each stage operated at its optimum DR and gain in series.
The front end is using the common mode gain reduction as it is, which is needed for optimum balanced line operation. That common mode shunt is why the low values are used in the gain switch.. It hides a multitude of evils in rock and roll, lol!
Originally posted by angelothewolf View PostThis equipment is from a dubbing studio. The owner claims that he needs a smooth gain control to adjust level by hand, while he's recording voice, due to instantaneus level increasing...
Originally posted by olddawg View PostOdd... Seems like he would do that at the console channel level. Varying mic sensitivity can cause a multitude of evils. Golden Ears I'm sure.... Wonder if he could tell the difference if you put a $30 Art mic preamp in a different box?
