1487 Silvertone with built-in amp questions
  • 1487 Silvertone with built-in amp questions
    Hi all,
    I was gifted a rare Silvertone guitar with a built-in amp and am working to bring it up to speed. I've addressed everything besides the electronics of it, so that's where I'm stuck. I understand there was an input for 2 9 volt batteries but it was missing, so picked up a couple of leads at Radio Shack but don't know how to wire it from there. I'm just learning up on circuits and such but thought I'd start with the basics to try to determine if there are any issues. One of the caps is pretty blistered up so expect I'll need to troubleshoot that. If anyone is game to help, please let me know and I can PM pictures of it all.
    Thanks!
    DanClick image for larger version
Name:	Amp circuit.jpg
Name:	Amp - power.jpg
      dang how did that happen!?
        Schematic and other info can be seen here:
        Silvertone World - Electric Guitars - 1960s - Model 1445 Schematic & Manual
          You can go back an edit. Also, please add a photo that shows the complete back side of the pick guard so we can see all the existing parts and wiring.
              Thanks for the call out. I just did now.
                Hi all, Did you get the correct wiring for the battery leads? I have the same issue with a Silvertone 1487. I know the pickup works as it plays on an amp but the batter leads were missing. Thanks!!
                  The link in post 4 still works. It shows a switch, and the battery (not sure what the voltage or configuration is) across the terminals of C6. C6 is the cap that the OP shows as 'blistered'. Maybe someone tried putting a battery there, but reverse polarity. Be sure to go positive-to-positive and neg-neg, to avoid blowing up the cap.
                  If you're looking for more specific instruction, someone else may chime in. I'm not familiar at all with these guitars.
                  Good luck, and welcome to the forum
                    Here is the schematic.
                    Top right is where the battery gets hooked up.
                    Unfortunately the board layout was a crappy scan.
                    Here is a snip of the battery circuit.
                      Be sure to wire the battery clip with correct polarity. The positive battery lead goes to ground.
                        Thanks for the help everyone! Will see if it works!!
