Hi all
So, fairly simple question but not sure which would be considered the most robust...
I'm making a DIY lightbulb limiter, a wooden box with plug socket and bulb socket on it. I need the earth on the plug socket, of course, but the bulb socket is also metal and requires safety earthing. Given that pig tailing with a screw on wirenut is not an accredited method here in the uk I wanted to pick brains on my other options -
1 - strip back the ground wire sleeve a few inches from the end, AND at the end, fold the exposed area in the middle of the sleeve and use that for the lightbulb. It's stranded core, I feel like this would probably be ok but I'm worried it might be considered bad practice...
2 - Install a chassis ground point like on a metal amp, wall earth to that, 2 wires off to the plug socket and bulb socket. I am kind of comfortable with this form but means the earth wire from the wall now has a non-continuos route to the ground pin of the plug socket... and I know that's frowned upon and, well, I don't want to cut corners on the safety earth of the DUT. Maybe it's not a problem if I follow the usual standards for a really secure safety ground... EDIT, less into this ATM, 3 mains earth connections on one terminal? Thinking more of making a ground strip with 3 terminals...
3 - Buy something like a terminal block with gangs to allow safe connection of more than 2 wires, comfortable wit this too but has the same problem as no. 2...
4 - Ground the bulb socket, with a separate wire, on the back-chassis of the plug socket by screwing it down to the mounting bolts on the inside side
It's a somewhat small thing technically but as it's such a hugely important thing, safety wise, I wanted to run ideas here too. I will probably ask the electrician at my work too when he's next in, before I build anything. As ever, I know the risks and am solely responsible for my final decision on how to connect it!
