Well, I know this is a really really old digital mixer, I'm using it for my poor economy
I got this for just about $230, I've successfully got its screen repaired by changing 3 caps on the lcd board.
Now I'm trapped in 3 problems:
1: If you've fully powered it off several minutes ago, then it'll be ok to power it on. But if you just power it off several seconds ago, for some reasons like I need a reboot or my power cord is pulled off accidently, all peak lights in the input zone will stay on, and for sure all inputs won't work. I also noticed in this case phantom power won't run, lights on the 48V switch won't be on, too. But the system will startup normally and it seems everything except analog input and output is ok. I've already changed all 1000uF caps on the input board.
2: The right side of the solo output is a bit lower than the other side, and I also noticed there's a big current noise on the right side. No matter the ctrlroom out, or PHONES, all the same.I've changed the opamps on the analog output board, and I've measured most of the tiny components and found nothing looks really wrong.
3: The PRESET number leds display wrongly, and LEDs next to every fader and monitor are a bit weird.
Everything you tell me leads to my great appreciation!
