Hello folks,
I am working on a Line 6 AX2. It defaults automatically to 'Tuner' when you release any button you select. In that mode you basically get straight thru processing w/no digital effects. I've pretty much as best as can determine that issue is in the main processor U9 (Line6 #15-84-8031 PCB80C31BH-3 most likely wouldn't be programmed if you found a generic one).
All the switching matrixing is functioning and the buttons are not shorted & have same resistance to ground on diode check as well as just straight resistance. I've also scoped the matrix to determine if the signals are being routed properly & they are to the best I can tell.
I even just to be thorough measured every chip cap & electrolytic for shorts. Diodes all ok, too. Fortunately there is a limited amount of them on the entire board.
When we did warranty for Line 6 way back in 2005 - 2012, they no longer had the board available for this model that was built in like 1997, so I'm doubting to get a board for it.
Has anyone had experience with this type of issue on this amp. I know this is a pretty remote chance but this is the best forum I've found and been a member of since about 2005.
I haven't searched for the processor or contacted Line 6 as I'm pretty sure that would be a dead end if you can even contact them since they were bought out.
Anyway, any ideas other than suggest the circular file
Thanx, Glen
Thanx, Glen
